Utility Network service not showing the latest updates in the data
351
04-07-2025 10:16 AM
wizgis
Hi Community,
Using the SDE login of PostgreSQL, we have successfully published a utility network service (branch-versioned enabled) to ArcGIS Enterprise. After publishing the service, we connected to the data using the database connection (SDE login) and reassigned the domain of a particular field. The changes are reflected properly at the feature class level; however, it still shows the previous configuration at the service level.
We have restarted the service. However, the issue is still there. Additionally, there is no named version and all the changes are being done in the default version.
Any input on this would be appreciated.
