Unable to Generate Tokens using SAML enterprise accounts
9468
15
05-06-2021 06:48 PM
tigerwoulds
Running a Federated 1081 Enterprise deployment with Azure AD as our identity store.
I am unable to generate a token using our enterprise login credentials. Tested from https://webadaptor.domain.com/arcgis/sharing/rest/generateToken
But I get this error:
It does work if I use a built in account that isnt tied to our IDP. Any ideas why this happening?
Scott_Tansley
MVP Regular Contributor
At 10.9.x or higher, you can login to the admin pages using SAML2.  Before then the portal admin pages needed a built in user.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
MichaelNüßlein
Dear Scott,
thank you for your response. We are working with 10.9.1 and our SAML-login manually works good. But i want to use the SAML login within a script on linux to automatically test the validity of the SAML signin certificate.
Scott_Tansley
I'm not a Python expert, but I would imagine you would need to find a set of libraries for supporting SAML2 due to the many interactions.  I'm not sure I've come across this use-case before.  Typically, scripts, because they are not human and so use OAuth (ArcGIS Token) account.  Note that SAML2 largely represents human users.
Scott Tansley
julian_svcs
@MichaelNüßlein, you may have seen this already, but here are all the options on how to connect using different authentication schemes:
https://developers.arcgis.com/python/guide/working-with-different-authentication-schemes/
AndresCastillo
I was trying to login to a saml account via arcpy signintoportal gp tool, but it is not supported:
https://community.esri.com/t5/arcgis-pro-ideas/support-for-enterprise-login-in-arcpy/idi-p/1015426
"We won't be able to support SAML logins because they can use different identity providers (PKI or IWA). The workaround already mentioned works—start ArcGIS Pro, sign in manually, and select the 'sign me in automatically' button"
Also, I tried authenticating directly to the saml account with the generateToken api, which is called by arcpy signintoportal under the hood, but also not supported:
https://support.esri.com/en-us/knowledge-base/problem-unable-to-generate-tokens-using-arcgis-enterpr...
"This issue is by design. It is not possible to allow token-based security with SAML-authenticated accounts without undermining the security provided by the SAML identity provider."
