I am working on getting all the item details filled out for my content on Portal. After doing this I want to save the layers to a geodatabase saved on my local drive. When I added my Portal content to a map in ArcGIS Pro, none of these edits to the item details are populating in Properties > Metadata or in View Metadata from the Catalog Pane. Why are these metadata changes on Portal not showing in ArcGIS Pro? From the Catalog View I also cannot Edit or Synchronize metadata and review a message stating "Editing metadata is not available for this item. This item must support metadata and you must have write access". I own this layer.
Are you unable to edit Portal layer metadata in Pro and do new edits to metadata in Portal not populate in Pro?
