Unable to connect to  arcgis server local
2424
10-25-2013 09:58 AM
by Anonymous User
Not applicable
Original User: RAMADAN27
I have ArcGIS Server 10.1 installed and running , and published the services  its worked , and setup & Configuration Web Adaptor
when i go the ArcGIS Web Applications for the Microsoft .NET Framework to create new web
i cannot add  arcgis server local  when i type the host machine Name or "localhost"  this message showing
Error: Unable to connect to server
what i can do please
[ATTACH=CONFIG]28620[/ATTACH]
[ATTACH=CONFIG]28621[/ATTACH]
by Anonymous User
Not applicable
Original User: ciava.at
You cannot connect to server 10.1 or 10.2 in local mode but you can connect server 10.0 in local mode.
see page 6 in http://downloads2.esri.com/support/TechArticles/W26496_W25918_DEPRECATION_PLAN_FOR_ARCGIS_101_and_10...
