To refresh a map tiled map service, do you just need to overwrite the cache? Or does the service need to be republished and the cache?
608
03-16-2020 10:00 AM
CarlVricella
New Contributor III
For one of my organizations application we have a large tiled map service for a large geographic area. Currently the service has just been manually republished every so often but now it was requested to script out the republishing of the service and to start doing it more often.
I am new to the organization was not there when this was all set up, also new to ArcGIS Services and Map services but I have a lot of scripting/programming experience so this task was assigned to me. My understanding from reading the docs is that the service itself does not need to be republished, just the cache, is this correct?
JakeSkinner
Esri Esteemed Contributor
Hi Carl,
Yes, you are correct.  You can execute the Manage Map Service Cache Tiles to do this.
JakeSkinner
Hi Carl,
CarlVricella
New Contributor III
Cool, thanks for confirming for me
