The function ID is out of range
1307
03-10-2013 08:14 AM
ArielLomes
Hello,
I'm having a problem with labeling parcels which are stored in a feature class inside a feature dataset on an 9.3 sde database, on MS SQL 2008 R2.
Whenever I zoom to the extent that the labels are set to appear, I get the following error:
[ATTACH=CONFIG]22499[/ATTACH]
The parcels themselves were created in ArcGIS Desktop 10.1, but we still have ArcSDE 9.3 installed in my organization.
The problem only occurs on that specific feature class. At first I managed to make it disappear by disabeling the maplex engine, but the problem returned after few times I opened and closed the MXD document.
Can anyone think of a solution?
Ariel.
WaelYahya
Please sendme a sample data to wael.yahya@gistec.com
JonathanQuinn
Esri Notable Contributor
Do you have joins set up in that mxd?  Can you recreate the MXD from scratch to see if the problem is reproducible?
ArielLomes
Yes, I have a join. When I remove the join, the problem disappears.
I will try to recreate the MXD to see if it's reproducible.
ArielLomes
Still the same problem now in another project, with exactly the same error after a join is done with a table.
