System/PublishingTools.GPServer OutOfMemoryError
2559
12-22-2020 10:26 PM
SaarthaAdmin
Hi all
i am getting the below error,
<Msg time="2020-12-23T11:28:26,848" type="SEVERE" code="7570" source="Server" process="3249" thread="32" methodName="" machine="gis.domain.com" user="" elapsed="" requestID="25d1ab37-c36f-4888-8526-a06fa1186633">Failed to construct instance of service 'System/PublishingTools.GPServer'. activation failed; nested exception is:
java.rmi.ServerError: Error occurred in server thread; nested exception is:
java.lang.OutOfMemoryError: unable to create native thread: possibly out of memory or process/resource limits reached</Msg>
ArcGIS Server version : 10.8
Did i miss any configuration?
Tags (1)
by Anonymous User
Not applicable
Hi @SaarthaAdmin ,
What is your resource usage currently sitting at? What underlying OS are you using to run ArcGIS Server?
If you are using linux please check to make sure you are not hitting any resource limits. See this doco:
https://enterprise.arcgis.com/en/system-requirements/latest/linux/arcgis-server-system-requirements....
Regards,
James
SaarthaAdmin
OS is SUSE
I think it is because of the user which the service is starting.
Yes now its working fine. i login to the ArcGIS admin user and start the services.
