Shoukd I use AGO Assistant or ArcGIS Assistant ?
5580
08-02-2022 08:27 AM
VirginieLe_Gal
Today, ArcGIS assistant (https://assistant.esri-ps.com) or AGO assistant (https://ago-assistant.esri.com/) are available.
I would like to know which one is recommended to use. Are there situations where one is better than the other ?
Thanks for your help
Virginie
Tags (1)
2 Solutions
KenBuja
MVP Esteemed Contributor
ArcGIS Assistant (V2) is the successor to ArcGIS Online Assistant (V1), using newer technologies. V2 has a more familiar interface, mirroring the standard AGOL interface, with some actual improvements to it (like hovering over a group icon tells you what group it is). In V1, it's easier to make bulk reassignments of services in a web map
jcarlson
Personally, I like AGO Assistant, because you can still get at the source code and clone / modify it to your liking.
https://github.com/Esri/ago-assistant
- Josh Carlson
Kendall County GIS
AdrianWelsh
MVP Honored Contributor
Officially, these are not supported by Esri, even though Esri personnel mention them, use them, and they're housed on Esri's website. Unofficially, the first link you listed is the latest version of the AGO Assistant. (the https://assistant.esri-ps.com/ link)
See this post for more info:
https://community.esri.com/t5/education-blog/arcgis-assistant-beta-tool-for-managing-content/ba-p/10...
KenBuja
jcarlson
- Josh Carlson
Kendall County GIS
VirginieLe_Gal
Thanks a lot for your answers. I see better which one I should use.
