Server;s publishing job did not succed
917
07-23-2012 10:12 AM
ShaningYu
Honored Contributor
I have tried to publish a map service for raster data.  My co-worker created a file-GDB rater catalog that contains more than 100 raster images.  My processing procedure is below:
1)  Create a mxd and load the Raster catalog file.
2)  Publish it as service.  It went through the Analyze.
3)  After I clicked Publish button, it took about 3 hours to copy the data to the server and creation of the Service Definition (folder size: 24 GB).
4)  The, received the error message (see the image).
[ATTACH=CONFIG]16334[/ATTACH]
I could view the GP Results actually.
Please provide your advice if you know.  Thanks.
ShaningYu
Honored Contributor
Found to be space required related.  Re-configure arcgisserver to a new drive that has a large space.
ShaningYu
Honored Contributor
