server publish a mosaicDataset ,image do not show
1642
04-19-2013 02:11 AM
chenjun
hi,i created a mosaicDataset and add some rasters(.tif�?in int . the tif file is from another machine . in arcmap i can see the image. befor i publish the mosaicDataset i can also see it. but i can not see it when the services published.  if the tif file is in local like D:\ or E:\ ,it works. i can see the image .  is there some one  run into it?
this is my mosaicDataset info, the Z:\  is a disk from another machine .
[ATTACH=CONFIG]23641[/ATTACH]
and i also register the folder
[ATTACH=CONFIG]23642[/ATTACH]
help ,help me
by Anonymous User
Not applicable
Original User: divyamg
http://support.esri.com/es/knowledgebase/techarticles/detail/39660
Take a look at this link.
