SDE connection failing after IP change
725
06-28-2011 05:55 PM
MōnoSimeone
The IT admins changed the IP of the server where I have SDE + SQLServer 2008 R2.
Tried using the SQL Server Configuration Manager > SQL Server Network Configuration > Protocols for MSSQLServer > TCP/IP and changing the IP values to reflect the new IP but it's not resolving the issue.
I'm not a server a guy or a dba just trying to build an enterprise gis for the college. Any protocols I should follow to get this back up and running?
M.
TonyContreras
What are you experiencing after this change? How are you trying to connect and what errors/messages do you receive?
