REST End Point Still Showing Old Alias of Updated Field After Publishing
1594
01-10-2019 11:40 AM
BehrouzHosseini
Using ArcGIS 10.6 and ArcGIS Server 10.6.,  I have changed the Alias of a Feature Class to ObjectID like
and it is showing in the attribute table like
(After Saving and even re-booting the MXD) but when I publish the map as Map Service the output still showing old alias (FID)  in the Service REST end point!
Can you please let me know why this is happening and how I can fix this?
MarisaClaggett
Hi Behrouz,
Are you overwriting a map service or publishing a new map service?  Also is this data located in an enterprise geodatabase or file geodatabase?
Marisa
BehrouzHosseini
Thanks for reply Marisa, I actually did both overwriting and publishing a new service but the result is same! The data is located on a File Geodatabase
MichaelMiller2
Did you clear the browser cache?
BehrouzHosseini
Thanks for reply Michael, Yes I already cleared the browser cache (even after publishing a new Service!)
RandallWilliams
When you publish, are you choosing the option to write your data into the service definition, or do you register your data store using ArcCatalog/ArcGIS Server?
http://enterprise.arcgis.com/en/server/latest/publish-services/windows/overview-register-data-with-a...
