Just setting up Portal... seems anyone that hits "Register" gets assigned a new account instantly. How do I require that a registration request be approved by an administrator role?
HI Cassandra,
Here's the doc for this:
http://server.arcgis.com/en/portal/latest/administer/linux/disabling-users-ability-to-create-builtin-portal-accounts.htm
Strangely, this isn't working. I can try and add this property, but then after a minute or so the page refreshes and the property is not set.
Hmm, are the curly braces set correctly?
{"disableSignup": "true"}
Yep, and typed in rather than copy pasted (to prevent extra characters being pasted in). Still doesn't work, curious.
Strange. I'm on 10.5.1 on Linux, works for me, the 'create an account' button is gone. Which version are you working with?
Did you try Disabling anonymous access—Portal for ArcGIS (10.5.x) | ArcGIS Enterprise ?
Sign in to the portal website as an Administrator of your organization and click the Edit Settings button.Click the Security link on the left side of the page.Uncheck the Allow anonymous access to your portal option.Click Save to apply your change.
If you're using web tier authentication (that is, you're performing authentication through ArcGIS Web Adaptor), disable anonymous access on your web server (For Windows).
Thanks Jayanta... but are you sure this applies to my situation? I don't want to restrict people from seeing the Portal resources outside of the organization; I want to restrict the ability to request for accounts without administrative approval. As it is, merely clicking "Create Account" instantly creates an account.
Disabling anonymous access will disable the option of registering to Portal by anonymous users from the landing page. Only those users can login, whose account have been created by the administrator (existing users).
All the maps that have been shared with public on landing page, could be seen by all the users without creating logins.
Thanks for the clarification. That does sound like it would solve the issue. I was expecting the ability to have people request accounts that are then approved by administrator. That would have reduced the administrative headache of getting everyone's contact info ahead of time and creating accounts for them. Nonetheless, this is better than allowing just anyone to request an account! Hopefully this solves the issue, though I am still curious and unsure why Randall's suggestion was not working.
Not true. After disabling anonymous access through Portal -> My Organization -> Edit Settings -> Security everything needs authorization. Even Home page requires login.
{"disableSignup": "true"} works only partially on my fresh install of Portal 10.5.1. There is no "Create account" on plain login page, but:
With those issues we aren't able to publish our Portal to the Internet. Any solution for above issues?
Hello Kuba, did you solved the signup issue you described? If so, how? Is this a bug?
It is still present at 10.6. You can change it by setting advanced portal options (see how) and changing signup variable to something neutral, eg.
signup: "index.html"
Regards
Kuba
