Hello - in prep for upgrade of our federated server site to 11.1 from 10.9.1, I removed the ArcMap based runtime after finally being able to remove my remaining ArcMap authored services. When I did this, like 30K + log files got dumped to the C:\ root.
I deleted the log files, restarted arcgis server service, went into server admin, re-edited the log output location (even though this did not change) to C:\arcgisserver\logs\
Now, on both machines, I am seeing .log files being written to-added to the C:\ root
Why is this happening? What can I do? There is nothing in this help step that says this will happen:
https://enterprise.arcgis.com/en/server/10.9.1/administer/windows/disable-arcmap-runtime.htm
@ChristopherCounsell
@VinceAngelo
David
