Relates and Joins Not Getting Published in ArcGIS Server (AGS) v10.2
2882
08-21-2014 09:33 AM
MichaelVolz
Esteemed Contributor
To All AGS Users:
I have joins and relates on feature classes originating in file geodatabases that reside on a file share available to a clustered AGS v10.2 environment.  The relates and joins work fine in the source mxd, but do not get published to the mapservice.  ESRI has thus far helped to identify that the problem is almost certainly due to Microsoft Failover Clustering which my organization is using to keep the data highly available.
Has anyone encountered an issue similar to this?  If so, would you know if your organization is using Microsoft Failover Clustering for the shared data?
Any help or feedback on this topic is greatly appreciated.
