Raster Catalogs and Image Mosaics
997
09-16-2012 05:55 PM
TimHayes
I see that in ArcGIS Desktop 10.1 Advanced you can create Raster Catalogs and Raster Mosaics in a File Geodatabase.
Can a Raster Catalog or Raster Mosaic stored in a 10.1 File Geodatabase be published as a Map Service? or is a license for ArcGIS Server Image Ext required?
NelsonDe_Miranda
You can publish the following, as an image service:
  • Raster dataset
  • Raster layer
  • Mosaic dataset
  • Mosaic layer
http://resources.arcgis.com/en/help/main/10.1/index.html#/Publishing_image_services/01540000045v0000...
I have ArcGIS for Server only.
You can only publish  raster datasets and layer files that reference raster datasets. You can  use either ArcCatalog or Manager to publish the service.
I have ArcGIS for Server and the ArcGIS Image extension .
    You can publish raster  datasets, mosaic datasets, or layer files that reference raster  datasets or mosaic datasets. You can use either ArcCatalog or Manager to  publish the service.
NelsonDe_Miranda
  • Raster dataset
  • Raster layer
  • Mosaic dataset
  • Mosaic layer
