R-ArcGIS Bridge Script Tool Publishing (as Web Tool)
3098
12-08-2020 12:02 PM
DylanMurphy
Has anybody attempted to publish a script tool created in R using the R-ArcGIS Bridge as a Web Tool before? A Web Tool I am working on relies on a R Script tool as part of the model. The model and the script tool itself both run successfully in ArcGIS Pro with no issues.
In testing this out, I have published the standalone script tool to my organization's Portal and, while it publishes successfully, when I attempt to run it within the portal it fails
My assumption is that I might need to install R, and the packages/dependencies used by the tool, onto the federated server that our Portal runs on. But, as someone relatively new to Enterprise and Web Tool publishing, I could be wrong about this.
Does anyone in the community have any insights into this process and/or experience sharing an R Script tool as a Web Tool in Portal? Any help would be appreciated greatly - this is something I have been stuck on for a while now.
by Anonymous User
Not applicable
Hello Dylan,
Thanks for asking this question. You are right, you need R on the server so that once your script tool makes R calls, it has access to the R interpreter.
We have seen some issues with timeouts lately, you may want to increase the timeout time limit in your portal. R can be notoriously slow and this results in a tool that just does not do anything in the portal, where in reality it just cannot finish and times out.
The most streamlined way of sharing the R web tool is creating a script tool in ArcGIS Pro and sharing it, it seems that is exactly what you have done.
Orhun
by Anonymous User
Not applicable
Hi Dlan,
The R-ArcGIS Bridge isn't officially support by Esri. But you may have success posting your question here as well:
https://community.esri.com/t5/r-arcgis/gh-p/r-arcgis
https://github.com/R-ArcGIS
Calvin
by Anonymous User
Not applicable
Hello Calvin,
Thank you for the resources. One correction: R-ArcGIS Bridge is an officially supported product of ESRI.
I will add to the great resources you shared with our new product landing page.:
https://www.esri.com/en-us/arcgis/products/r-arcgis-bridge/overview
Orhun
by Anonymous User
Not applicable
Hello Dylan,
Orhun
DylanMurphy
Thank you, Orhun!
This project got shelved, but this will certainly be useful in any future scenario where I need to share a tool that utilizes the R-Arc bridge though our Portal.
by Anonymous User
Not applicable
No problem, Dylan!
In order to make the future process easier, below is a link that outlines the steps of getting R setup on your server. Hopefully, these steps will minimize the number of moving parts and make using your R tools on Portal easier.
https://enterprise.arcgis.com/en/server/latest/publish-services/windows/deploying-r-for-arcgis-serve...
