Publishing Service on ArcGIS Server Manager with 10.4.1 error.
2757
02-05-2017 07:49 PM
LeoDeng
I've installed ArcGIS 10.4.1 for Server and ArcGIS 10.4.1 for Server Publishing Patch (http://support.esri.com/download/7397).
When I login the ArcGIS Server Manager and publish service with *.sd file, it still not success.
The same operation in ArcGIS 10.3.1 is successed.
Environment:
Windows 8.1
ArcGIS 10.4.1 for Desktop
- Additional:
Browser: Google Chrome v55.0.2883.87 m(64-bit)
SD file size: about 90 KB
ArcGIS Server directory: C:\arcgisserver\  (installed by default)
Tags (1)
JayantaPoddar
Thank you for providing further details. It could be the issue with Google Chrome.
ArcGIS Server Manager Upload Patch
Recent browser updates result in errors when attempting to upload certain files in ArcGIS Server Manager. As of Firefox 49, Chrome 54 and Safari 10, uploading service definition (SD), server object extension (SOE), KML network link (KMZ), or database connection (SDE) files will produce errors.
Alternatively, you could work on Internet Explorer. It should work.
Think Location
JayantaPoddar
Hi Leo,
What is the size of the SD file?
If the service definition you are publishing includes source GIS datasets, the size of the data and your network bandwidth impacts the time it takes to publish. Service definitions over 2 GB in size cannot be published using the Internet Explorer or Firefox web browsers; therefore, use Google Chrome for service definitions over 2 GB.
Also ensure that the Current User account and ArcGIS Server account have read/write access to Config-Store directory (<ArcGIS Server installation drive>\arcgisserver\config-store).
Think Location
LeoDeng
The size of SD file is about 90 KB and the browser is Google Chrome.  The config-store directory is created by arcgis server installation and setting by default (C:\arcgisserver\config-store).
JayantaPoddar
Think Location
MichaelVolz
Esteemed Contributor
Chrome 56 has been released.  Does this issue still persist with Chrome 56 at versions such as AGS 10.3.1?
