Publishing mosaic container with the command ???share image as service???,
1682
09-04-2013 09:25 AM
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Publishing mosaic container with the command �??share image as service�?�,
I wanted to publish a mosaic container but sounds to be published successfully. The issue here that when the service is added to the ArcMap, the �??zoom to layer�?� produces nothing while the �??zoom to source resolution�?� displays the image.
[ATTACH=CONFIG]27204[/ATTACH], [ATTACH=CONFIG]27205[/ATTACH]
As the service is added to a web application, nothing appears
[ATTACH=CONFIG]27206[/ATTACH], [ATTACH=CONFIG]27207[/ATTACH]
What might be the issue here?
Thank you
Best
Jamal
nicogis
with firebug what do you see in net tab (request rest) when you click 'go to'? so you can understand what can be the problem.
by Anonymous User
Not applicable
Many thanks Domenico for the help,
The issue here that the published imagery can be zoomed (in the ArcGIS desktop) by �??zoom to source resolution�?� but not by �??zoom too layer�?�. Also, I can see nothing in the published imagery
[ATTACH=CONFIG]27255[/ATTACH]
Please, have a look what fiddlers says:
[ATTACH=CONFIG]27256[/ATTACH]
Best
Jamal
JamalNUMAN
Legendary Contributor
Hi Domenico,
I got the help below:
Images contained in mosaic data are disappeared at particular scale. To get them appeared at all scales the �??build review�?� tool must be used.
[ATTACH=CONFIG]27831[/ATTACH], [ATTACH=CONFIG]27832[/ATTACH], [ATTACH=CONFIG]27832[/ATTACH]
That solves my issue as well. It can be viewed from the web mapping application with no problem
[ATTACH=CONFIG]27833[/ATTACH]
Best
Jamal
Jamal Numan
