publish a feature service from a file geodatabase - true or false?
5617
8
04-07-2016 09:44 AM
deleted-user-AzQ5lcTQbS2a
trying to publish a layer from a file geodatabase to enable editing through collector or web app builder, but want to keep data local, not the AGO cloud. Is this possible?
Help is giving me mixed reviews:
1) unregister the data source from the server so that data can be copied to the server
2) register the data with the server to enable feature access
So can I please get a yes or no confirmation whether or not you can edit file geodatabase through a feature service?
thanks!
MichaelVolz
Esteemed Contributor
The documentation says that it need to be an SDE database, so its False.
Thanks.... just needed a 2nd opinion.  Also, finding out SQL Express is not an acceptable SDE substitute.
AlexanderBrown5
Stacey,
If you have a workgroup license for SQL Express you can publish live feature services from that.
Register a workgroup geodatabase with ArcGIS Server—Documentation | ArcGIS Enterprise
~Alex
JohnBrockwell
False
AdrianWelsh
MVP Honored Contributor
Stacey,
If your file geodatabase is on your server and you publish it as a map service, is it editable then?
JonathanQuinn
Esri Notable Contributor
No, that's not possible, but you can register the ArcGIS Data Store as your managed data store and when you publish file geodatabase data and select feature access, it'll copy the data into the ArcGIS Data Store so it can be an editable feature service, (note that the linked documentation refers to enterprise geodatabases but the content is relevant to ArcGIS Data Store).  The data in the service will then point to the copied data instead of the original source data.  You can always edit it in ArcMap by creating a local copy for editing.
deleted-user-QihobtYldS9C
Thanks Johathan for the explanation. The copy the data function defeats the purpose of live updates/editing..
JonathanQuinn
If you're publishing to Portal and the data is copied into the ArcGIS Data Store, you have the option of creating a tile layer or hosted feature layer.  If you're publishing a hosted feature layer, they can be edited in clients such as the web map viewer, any web application that supports editing, and desktop clients like Pro and ArcMap.
About hosted layers—Portal for ArcGIS | ArcGIS Enterprise
