Promoting services from Test/staging to Production
1526
12-20-2018 09:27 AM
by Anonymous User
Not applicable
  • Promoting services from test to production- what is the best practices for promoting services and keeping pathnames intact, even though they are pointing to a different source. Not only the server we are publishing to but the source data as well. Example below
What do we need to do to allow an agency admin to publish to CAT/Test using CATSQL Geodatabase as its source data.  Then pass on to us a service definition that I can then publish to Production using ProductionSQL Geodatabase as its data source.
MichaelVolz
Esteemed Contributor
Are both databases SQL Server databases?  Is CATSQL and ProductionSQL just different names for SQL Server databases?
by Anonymous User
Not applicable
Yes they both are SQL server databases- CATSQL is the testing and Production is a production SQL database
KyleGonterwitz
MVP Alum
System Aliases for everyone.... System aliases to UNC paths for connection files, system alias on databases, registered connections in server, map services, application configurations...
Update stuff and have network admins transfer system aliases to the updated environment.
