When I unzipped the SLP download I found a document called "System Log Parser Installation Guide.docx". The installation directions include:
"Double click SystemLogParserInstaller.exe. The installShield Wizard will start".
Is this accurate? I cannot find the file "SystemLogParserInstaller.exe" anywhere in the ZIP file I downloaded (SystemLogParser.zip, version 0.12.9.0).
However, if I run the file "SystemLogsGUI.exe" the program appears to work. I think the doument "System Log Parser Installation Guide.docx" is incorrect and needs to be updated. Can anybody confirm this for me? I don't want others to have this same problem.
Bernie.
I found the answer. See the section outlined in red below:
"The latest version does not include an installer."
The document is incorrect and it needs to be updated. All you need to do is extract the files to a folder on your hard drive and run the file "SystemLogsGUI.exe".
Hi Bernie,
How did you find out about this utility?
The Client IP Request graph on the IIS tab and others are very helpful.
