Portal User Index out of sync
1016
01-10-2025 01:55 PM
Dan_Brumm
Recently upgraded to 11.4 and our Portal index for users is out of sync.  The group and item indexes are fine.
1. Tried rebooting
2. Tried reindexing and reconfiguring
Any ideas?? all suggestions are welcome!!
Dan
Error reindexing 'USER_MODE'. java.lang.RuntimeException: java.lang.Exception: The server at 'https://xyzxyz.xyzxy.NET:7443/arcgis/sharing/rest/config/indexer/reindex' returned an error. Error running reindex operation. ["java.util.concurrent.ExecutionException: java.lang.NullPointerException: Cannot invoke \"com.esri.gw.data.GWUser.getUsername()\" because \"<local4>\" is null"].
Daniel Brumm
GIS Nerd
Dan_Brumm
Daniel Brumm
GIS Nerd
DavidPike
MVP Notable Contributor
Do the logs (debug) give any more detail.  I'd have a look at that GWUser and maybe delete them out if possible.
TimSwalin
Running into this issue as well. Recently upgraded to 11.4 and noticed the index difference. Index has our count off by one. Running reindex with user mode does not appear to index anything. Portal log has no information about trying to run the index.
TimSwalin
Changed log level to debug. received an error. When deleting it states the index does not exist, when creating it states the index already exists.
DanielFox1
Hi @Dan_Brumm
Before you upgraded did you have the Living Atlas enabled and was your environment upgraded with the Living Atlas disabled or enabled?
Can you try this workflow to see if it works:
Enable Living Atlas on Portal -> Organization -> Settings -> Living Atlas
After enabling Living Atlas on the bottom click the Configure content.
Then check your indexes again and reindex if needed.
