Portal License
670
02-08-2018 10:45 AM
Khalid_AQureshi
I have installed ArcGIS Enterprise Standard in my organization. I believe ArcGIS Portal is part of license by default. Do I have to ask ESRI for ArcGIS Portal authorization?
DerekLaw
Esri Esteemed Contributor
Hi Khalid,
Portal for ArcGIS is included with ArcGIS Enterprise Standard, but it uses a separate license file to activate (i.e., separate from the license file for ArcGIS Server). I suggest you check with Esri customer service to obtain it.
Hope this helps,
