Anybody else experiencing the issue that my features values don't show up in the popup but they are in the attribute table?
My data is stored in a postgres db and have published the data as feature and map image.
I have tested using the standard popups and even tried configuring custom popups but have the same issue.
Experienced this issues in Enterprise 10.6.1 & 10.7.1.
I feel like if this was a common occurrence there would be a lot more noise about it as it severely impacts what users can see in their browsers and in the field with Collector.
I was wondering if anybody had any ideas that could help?
The image below shows the populated (I blurred out the data) values in Pro before publishing them
The image below shows the feature service with most of the values (blurred out) showing except parcelID
The image below shows the image service with basically all values missing
Greetings Tolo,
I do not have an answer right out of the gate, but I do have some questions.
Are you using Arcade to calculate attribute values? Have these values been edited in Pro post publishing? What version of Postgres are you using here? Are there domain values or subtypes applied here? Do we see this same behavior in all feature services originating from this Postgres database? If we used a file geodatabase just as a test, do we see the same behavior?
I am hoping that we can narrow down whether this is data specific, database specific, or a systemic issue.
-Andrew
Hey Andrew,
Arcade is only used for the [Address] field
Service is non editable
11.2
None
Tested a file geodatabase and it worked correctly
This does look like a database issue?
Greetings Tolo,
I have seen Arcade expressions cause incorrect values to display, but I do not think that is what you are seeing here. Perhaps there is conflict with the Postgres database here. Portal for ArcGIS also uses Postgres, so I wonder if there is a database conflict.
Is the database on the same machine as Portal for ArcGIS?
-Andrew
Yes I have also seen that with arcade expressions.
Sorry the only postgres database we are using is the Portal for ArcGIS db setup by ESRI Australia.
To anybody else who may come across this issue.
Have figured out that if you add the Image Service by going to "Add" --> "Search For Layers", the pop ups do not work correctly. Even after removing and readding the popups.
Instead if you grab the REST URL and add the Image Service by going "Add" --> "Add Layer From Web", the pop ups will work correctly. The only downside is that the user needs to "Enable Popup" and then configure the popup for each WebMap when adding the REST URL.
Have been working with ESRI Australia tech support and apparently this is a bug: BUG-000116500
This bug has existed since 2018 so I am suprised that it is still an issue.
