Oracle Enterprise GeoDatabase Question
1718
02-28-2024 07:24 AM
DRae
Hi I am new to the geospatial analysis. In my environment, there is an Oracle Enterprise GeoDatabase setup for the GIS Server, and Portal. I want to learn how to do the spatial analysis with SQL, I want to know where I can get the document for function like ST_Geometry. Thanks
2 Solutions
MarceloMarques
@DRae - If you plan to use SQL  to access the spatial data stored in the Geodatabase with Esri ST_GEOMETRY Spatial Data Type, then the ArcGIS Client that you use to create or upgrade the ArcSDE Geodatabase Repository "does matter". Why? Because of bug fixes, enhancements, etc.
Note: ArcMap 10.8.x will retire, and customers need to switch to ArcGIS Pro.
ArcMap Life Cycle | Esri Support
The best practice is to keep the ArcGIS Client version and the ArcSDE Geodatabase Repository Version at the same ArcGIS Version to avoid issues.
Read the details in the link below.
Client and geodatabase compatibility—ArcGIS Pro | Documentation
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
Bud
Esteemed Contributor
I would argue that it doesn't matter. Esri hasn't made any changes to ST_GEOMETRY in years. So, I think the documentation applies to both ArcMap and ArcGIS Pro. And I would be surprised if you're using a version of either that is so old that it doesn't match the docs.
At any rate, here is the ST_GEOMETRY documentation for ArcGIS Pro. As far as I can tell, the content is the same as the ArcMap link.
ArcGIS Pro - Databases and ST_Geometry - See the PDF link at the bottom of that page: https://pro.arcgis.com/en/pro-app/3.0/help/data/databases/pdf/stgeometry_reference.pdf
Bud
MarceloMarques
SQL and enterprise geodatabases—ArcMap | Documentation (arcgis.com)
The ST_Geometry storage type—ArcMap | Documentation (arcgis.com)
SQL functions used with ST_Geometry—ArcMap | Documentation (arcgis.com)
DRae
Is it matter that I am using ArcGIS Pro instead of ArcMap for the ST_Geometry?
MarceloMarques
Bud
