New Map Viewer - Pop up configuring not reflected in table view?
1112
01-23-2023 06:42 AM
RandyMcGregor3
in classic map viewer, the adjustments you make to the popup are reflected in the table view - ie if you remove 3 fields from the popup, you will NOT see these three fields in, say, a detail panel in a dashboard. I have noticed that when you configure a popup in the new map viewer, these changes are not reflected in other items that display attributes. ie - what you see in the detail panel does not reflect the changes you made to the popup.
How does one control fields/alias' etc... for attribute display in new web map viewer?
Thank you,
Randy
jcarlson
When you say "detail panel", are you talking about a dashboard? Or one of the configurable apps? Or something else? I see you did specify that, I'm sorry. I should ask, in your dashboard, are you pulling in the layer directly, or via a map?
Adjusting attribute displays in the new map viewer are done outside of the popup, in its own section of the right toolbar.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
RandyMcGregor3
Thank you. That's good. Also (I just discovered) when you open a table in new map viewer and select the gear, you get an option to control field-visibility. This does control what appears in a dashboard detail panel as well. Separating popups from other table views makes a lot sense.
