Network Diagram Not working with feature service
837
10
10-09-2025 04:35 AM
RaghavGupta
Hi
I am able to create network diagram when I am using database connection from enterprise geodatabase. However, When I am adding the service for same it is not able to create the network diagram. the error says " 002930: Failed to create diagram".
I have checked thoroughly the database is branched version. The diagram template is visible at service rest endpoint. I am trying to create the network diagram at ArcGIS Pro. I have even tried opening the new aprx and then tried but still it didn't work.
Has anybody faced this before or this is the reported bug in ArcGIS Pro 3.5.3.
@RobertKrisher , Can you please help here.
Thank You
Regards
Raghav
RaghavGupta
Hi AnneYvonneBlin
Since it was the business requirement, therefore we were using subtype group layer and it was creating the problem in network diagram creation from rest endpoint. But when we have added the standalone layers without any subtype group layers and published as a service, it is working perfectly fine.
So, may be there is some bug when we try to consume the subtype group layers from rest endpoint, it is not able to able to generate the network diagrams.
We will schedule a call to discuss further on this.
Raghav
