most efficient methods to insert/update feature table data in sql server using Arcgis Pro
1418
12-22-2023 03:35 AM
abhishek_choudhary
I'm utilizing a SQL Server database as our primary enterprise data repository. I've established a feature class within this SQL Server setup. Currently, I'm seeking recommendations on the most efficient methods to insert/update data into this table. Specifically, I'm looking to integrate data from the following formats: 1) CSV files, 2) shapefile datasets, and 3) file geodatabases. Additionally, if there are alternative methods to acquire and update this data, I'd appreciate suggestions on those as well.
Thanks & Regards,
Abhishek Kumar Choudhary
VinceAngelo
Esri Esteemed Contributor
This is a really broad question. The "most efficient" method depends on the nature of the data, the way the data is managed, and the nature of updates, and your experience and skill in ETL solutions.   The source formats are somewhat trivial; it's what you need to do with them that matters.
Some folks have no problems taking 10 minutes to update 100k rows via a Portal API, while others are updating 100 million rows every 8 hours.
Once you add in different ways to acquire data, well, there are too many options beyond generic advice like "As efficiently as possible."
If you want specific advice, you'll need to provide more details on the process you are trying to optimize.
- V
MarceloMarques
@abhishek_choudhary
 Question: "I'm looking to integrate data from the following formats: 1) CSV files, 2) shapefile datasets, and 3) file geodatabases. Additionally, if there are alternative methods to acquire and update this data, I'd appreciate suggestions on those as well."
Answer:
  • ArcGIS Pro Model Builder
  • ArcGIS Pro Python ArcPy Script
  • ArcGIS Pro Data Interoperability Extension
  • Safe Software FME Workbench / FME Server
If you are a SQL Server Administrator and an ArcSDE Geodatabase Administrator then read my white paper.
community.esri.com How Load Large Featureclass SQL Server Geodatabase
For more best practices visit Mapping and Charting Solutions (MCS) Enterprise Databases Best Practices
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
