License on Geodatabase has expired - how to renew??
2707
03-04-2013 10:56 AM
BryanKaraffa
Getting this error when connecting to our Geodatabase:
"Failed to connect to database.
No ArcGIS server license found.  Contact your geodatabase administrator to update license."
Image:   http://ctrlv.in/166716
I can generate license files and we have a license server for concurrent licencing... not sure what I need to do to go about updating the Enterprise Geodatabase licenses... any help would be much appreciated!
nicogis
-To authorize the geodatabase when it is being created, specify the authorization file location when you run either the Create Enterprise Geodatabase or Enable Enterprise Geodatabase geoprocessing tool or Python script.
-If you already created your geodatabase and need to reauthorize it, run the sdesetup command with the update_key operation.
