Labels and ArcGIS Enterprise
1313
05-19-2023 09:08 AM
LyonMNGIS
I will be implementing a federated server soon and I want to know how to publish services so that I can retain more control on label placements on my maps.  I understand that I can publish maps to portal which provides the limited label placement controls that are already available in the AGOL Mapviewer.
How do I publish maps with more cartographic control over label placements?  I would like to take advantage of various functionality for position controls, fitting strategies, conflict resolution, and label priories.  For example can we still publish a map with a curved label with the option to reduce font size?
TanuHoque
@LyonMNGIS
Share maps that your authored in ArcGIS Pro as map image layer to your portal.
https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/map-image-layer.htm
Behind the scene it creates a portal item of type "map image layer" that points to "map service" that gets created during the sharing process.
Hope this helps
TanuHoque
@LyonMNGIS
Hope this helps
LyonMNGIS
@TanuHoque
Thank you for your help.  I was told by another rep that we had to configure our services using the map viewer which just did not seem right.
