Issue Publishing SLPK from ArcGIS Pro to ArcGIS Enterprise - Token Generation Error
839
01-28-2025 12:44 AM
MarGIS
Hello Everyone,
I am encountering an issue when attempting to publish an SLPK from ArcGIS Pro to ArcGIS Enterprise. The publishing process fails with the attached error message from ArcGIS Pro. Additionally, I noticed several logs in the Portal that include the following message:
StatusMessage: Retrieving JobStatus for a41be3db3ef9492193ed84f8704b1e21: Job ID : jf582265badce4f3f943c54e2d6c82de7, Status : failed, Status Message : Invalid Token
It appears that ArcGIS Server is trying to generate a token from the Portal sharing REST API but cannot do so. After further troubleshooting, I found that the URL passed to the Portal is being redirected by the internal load balancer, as shown below:
- Passed URL: `https://abc-prd-prt-lb.domain:7443/arcgis/sharing/rest/generateToken`
- Redirected URL: `https://abc-prd-prt-lb.domain:7443/portal/sharing/rest/generateToken`
and this resulted not found page as the attached
### Additional Information
Environment Deployment: Highly Available
Enterprise Version: 11.4
Operating System: Windows Server 2022
ArcGIS Pro Version: 3.4
Portal system properties:
- `WebContextURL`: `https://gis.domain/portal`
- `privatePortalURL`: `https://abc-prd-prt-lb.domain:7443/arcgis`
Hosting Server security configuration:
```json
"portalUrl": "https://gis.domain/portal",
"privatePortalUrl": "https://abc-prd-prt-lb.domain:7443/arcgis",
"serverUrl": "https://gis.domain/hosting",
"privateHostingServerUrl": "https://abc-prd-srv-lb.domain:6443/arcgis"
There is currently no WebContextURL configured for the hosting server. While I understand that it might not make sense to configure a WebContextURL for a federated hosting server, I previously tried setting it to `https://gis.domain/hosting`. However, this caused issues with the "Operation Health" script, as the hosting server's administrative URL became unreachable. I subsequently removed the WebContextURL setting.
Load Balancer Update Health Check configuration:
- Protocol: HTTP
- Port: 7443
- Interval: 30,000 ms
- Timeout: 3,000 ms
- Retries: 3
- Status Code: 200
- URL Path: `/arcgis/portaladmin/healthCheck`
### Questions
1. Are there any incorrect properties in my current configuration?
2. Are there any additional properties I should configure to resolve this issue?
I would greatly appreciate any guidance or insights on how to fix this problem.
Thank you in advance!Page Not Found Error Using LB URL.pngArcGIS Pro Log File continued.pngArcGIS Pro Log File.png
BillFox
MVP Notable Contributor
curious:  as a different first step, can you try the share package tool? does it complete successfully?
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/share-package.htm
MarGIS
Thanks, @BillFox, for responding to the post. Yes, the process does complete successfully. Additionally, based on my findings, when the publishing failed previously, I noticed that the SLPK file was successfully uploaded to the Portal. However, it seems that the hosting server is unable to generate a token from the Portal to extract the file and complete the process.
BillFox
after the manual share to portal, does that publish button succeed for you?
MarGIS
I tried to publish but it failed. You can see the screen named (WebDeveloperTools). When I did not find any error in the browser, I visited Portal Logs and Found the logs in screenshot named (PortalLogs_edited). I tried to republish again from ArcGIS Pro and collected the logs in sequence regarding the process from start until it failure in screenshot named (PortalLogs2_edited).
