Is SAML 2.0 now supported in ArcGIS Server?
8719
12
12-20-2014 05:52 PM
TinaSmith
Is SAML 2.0 token-based authentication supported in ArcGIS Server?
NicolasGIS
Honored Contributor
All right Derek, thanks for your quick answer.
Nicolas
AnirudhNegi
Hi Derek,
We have configured our portal for SAML 2.0 authentication having IDP as SCI(SAP Cloud Identity).We are able to login directly into the portal using the Enterprise credentials(SP Initiated Login), however when we try to access the content of the Portal(let say Mapimagelayer) from the application after being authenticated from the IDP, we are challenged for the identity.
Is their something more that we have to configure or have to add some code in the application for leveraging the SAML SSO.
Regards,
Anirudh Negi
DerekLaw
Esri Esteemed Contributor
Hi Anirudh,
> We have configured our portal for SAML 2.0 authentication having IDP as SCI (SAP Cloud Identity)
Please contact Esri Tech Support and open an incident so they can take a look at your deployment and SAP Cloud configuration settings. They are best equipped to investigate your issue.
Hope this helps,
