Is SAML 2.0 token-based authentication supported in ArcGIS Server?
Hi Tina,
At the 10.3 release, ArcGIS for Server Standard and Advanced includes Portal for ArcGIS. Portal for ArcGIS supports SAML 2.0 authentication. Learn more in this help topic:
Configuring a SAML-compliant identity provider with your portal—Portal for ArcGIS | ArcGIS for Server
You can federate your Server site with Portal, enabling your Server site to leverage SAML.
Federating an ArcGIS Server site with your portal—Documentation | ArcGIS for Server
Hope this helps,
Thank you! Is there any way to do this without the use of portal?
My Best Regards,
Tina R. Smith
Principal Geospatial Intelligence SpecialistOffice of the Chief Technology OfficerVOIP 773-477-0937tinaraquel@hotmail.com
No. You will need to federate your ArcGIS Server site with Portal for ArcGIS if you want to leverage SAML authentication for it.
Hello Derek,
Do you know if SAML integration is in ArcGIS Server's road map and Portal for ArcGIS is mendatory only temporarily or do you consider this solution as sustainable ?
Nicolas
Hi Derek,
Just to be sure, using Portal for SAML purpose means that you need as many 'named users' as there are people accessing secured services though people won't be using Portal for ArcGIS anyway ?
Cheers,
Hi Nicolas,
In the context of this discussion, yes. Users that need to access secured web services - which were originally accessed directly from the GIS Server, but now the GIS Server is federated with Portal for ArcGIS, and leverages Portal's SAML authentication model; these users will have to be named users.
All right Derek, thanks for your quick answer.
Signed in members can post, follow updates, and more. New here? Register a free account.
