Is possible to have Survey123 web in an ArcGIS enterprise 16.1 instance?
3303
8
02-14-2018 07:25 AM
Cristian_Galindo
I just installed an ArcGIS Enterprise 16.1, I was wondering if I can offer to my users the possibility to have Survey123 in a web environment, either for the creation of surveys as well for the submission of data in surveys.
I was reading Administrator guide of Portal for ArcGIS, and did not found anything regarding that.
JonathanQuinn
Esri Notable Contributor
Do you mean 10.6? In any case, Survery123 is for any ArcGIS Enterprise deployment between 10.3.1 and the current release, (10.6):
System requirements—Survey123 for ArcGIS | ArcGIS
ArcGIS requirements
To use a form in Survey123, you must have an ArcGIS organizational account. To create forms in Survey123 Connect, you must have an ArcGIS organizational account with publishing permissions. ArcGIS Online and ArcGIS Enterprise 10.5 and later are supported. Portal for ArcGIS is supported at 10.3.1–10.4.1.
Cristian_Galindo
Hello Jonathan,
You are correct regarding the version, I mean 10.6.
Regarding the quote you state, it does not answer my question: "I was wondering if I can offer to my users the possibility to have Survey123 in a web environment, either for the creation of surveys as well for the submission of data in surveys."
I have been looking around and it does not show any option to activate it.
I can confirm, that if I publish a survey from Survey 123 connect or submit data using Survey123 (windows/android) application, the data is stored in the ArcGIS Enterprise instance.
RandallWilliams
I'm unsure I understand the requirement here. Any web environment requires a server to host the application - otherwise there's nothing for the client to communicate with.
Can you please restate your question?
JonathanQuinn
Do you mean reaching Survey123 through a browser?
Ex.
https://survey123.arcgis.com/
If not, as Randall Williams‌ asked, please elaborate on your question.
Cristian_Galindo
You are correct Jonathan, I mean reach Survey123 through a browser.
by Anonymous User
Not applicable
Hi Cristian,
Is the functionality you are looking for the same as shown in this video - Configuring Survey123 for ArcGIS Enterprise - YouTube ?
Regards,
Nic
AndrewHeimark
Do you know when this fuction will be out of developer's beta or is there a new link to point to?  The video was posted over a year ago and we are still pointing our portal survey's to the developers site.
Drew
DerekLaw
Esri Esteemed Contributor
Hi Cristian,
> ArcGIS Enterprise ... I was wondering if I can offer to my users the possibility to have Survey123 in a web environment, either for the creation of surveys as well for the submission of data in surveys.
Just to elaborate on Nic's post and the video that was referenced; the answer is "no". The Survey123 website is currently not fully supported with ArcGIS Enterprise. Right now, only the Analysis and Data tabs in the Survey123 website works with Enterprise. Survey creation via Web Designer and submitting surveys through a web browser are not supported.
FYI: How To: Configure Portal for ArcGIS to work with survey123.arcgis.com
However, enabling the Survey123 website to work with ArcGIS Enterprise is an open requirement for the Survey123 Dev team. Please vote for the enhancement on the ArcGIS Ideas site,
Hope this helps,
