Is it possible to publish an XY event layer to Arc Server (or ArcGIS Online)? I am trying but keep getting this error: 001270: Consolidating the data failed
8336
12
05-10-2016 08:25 AM
BobBistrais
I am trying to publish XY event data, either to ArcGIS Server or ArcGIS Online.  The data comes from two tables that are joined (one table contains attributes, the other has the XY location data).  The XY event layer derived from this works well in ArcMap, but when I try to publish in ArcGIS Server, I get the following message: 001270: Consolidating the data failed
-The data is all in a file GDB which has been registered to the ArcServer.
AnthonyKobah
One more thing, create a new connection to your ArcGIS Server (In ArcMap) using http.
Am assuming your site's protocol is set to both HTTP and HTTPS. Try publishing with the new connection.
BobBistrais
Nope, still gives the same error message as earlier.
FernandoGonzales
Hi, it`s works in arcgis 10? it`s posibble to set a No available Connection
