I upgrade my server from 10.2.1 to 10.3.1 and now I cannot run any of my GP services and cannot use new ones too.
In the simplest example I created a model with buffer tool with the result defined as an output parameter.
I run the tool in ArcMap and publish it to the server.
When I run it as GP service (both from ArcMap and WAB) I get error message.
After I checked the server log and checked the server directories I found that a scratch gdb was created in C:\arcgisserver\directories\arcgisjobs\buffer_gpserver\<SomeGUID>\scratch
This gdb cannot be accessed by ArcMap (get error) and when I use windows explorer I found the result as shape file within the scratch.gdb directory.
It looks like it creates a gdb and then use it as a simple directory and create shape file in it.
The server is sending this parameter automaticaly and it is wrong.
Is there any way around or I have to reinstall my server (and lose all my services).
Thanks
Mody
Check with Server Manager if your "jobs" directory is now the same as it was with the previous server version.
My screen looks just like yours (my arcgisserver directory is on C:)
