Install Server and Portal Patches with PowerShell DSC
7800
12
01-21-2020 12:37 PM
KrystalPhaneuf2
I'm trying to figure out how to have patches installed when running the PowerShell DSC for an enterprise upgrade from 10.6.1 to 10.7.1.  In the github Wiki I see "PatchesDir" in the variables page but all it says is optional.  I'm wondering if this directory is where I need to download the patches to be installed or where the patches will be installed to.  Would this be the same as "InstallDir"?  What filepath are patches usually installed to?
Variables reference page for JSON configuration files · Esri/arcgis-powershell-dsc Wiki · GitHub
Cameron Kroeker are you able to assist?  Thanks!
CameronKroeker
Just to confirm the recommended/supported workflow for applying patches after an upgrade, is to re-run the PowerShell module with -mode install. This is so that the upgrade can be verified and a backup/snapshot can be made prior to applying patches.
KrystalPhaneuf2
Yes, this is the workflow that worked for us in our last upgrade.
by Anonymous User
Not applicable
Adding a question to this topic.  When the config file asks for a Dir it is just the folder structure but when it asks for a Path that includes the actual file name and extension as well correct?
