install Arcmap with Enterprise 10.9.1
1062
03-16-2022 08:38 AM
DasheEbra
dears i use Enterprise 10.9.1 with ArcPro, i want to install ArcMap 1081 i don't want to use it with Enterprise, i just work some times with ArcMap instead of ArcPro. But it gives me the following error, so any way to use ArcMap with Enterprise 10.9.1?
Tags (1)
Brian_Wilson
Honored Contributor
You're trying to install Enterprise and Desktop on the same machine? Bad idea. Install Desktop on a desktop and Enterprise on a separate standalone machine.
ReeseFacendini
Esri Alum
I agree with @Brian_Wilson that you should install ArcGIS Desktop on a different machine, but if you need to have them on the same machine you will need to install Desktop 10.8.2 instead of 10.8.1
DasheEbra
thanks @ReeseFacendini @Desktop 10.8.2 doesn't appears on my ESRI downloads page, where or who can i get it!
Brian_Wilson
Honored Contributor
If you are only doing testing and you really don't have another machine available then you could probably install Enterprise in a virtual machine using VirtualBox. That would isolate it.
Make sure the machine can run VirtualBox and make sure you have a LOT of RAM installed. 32GB or more. Then again, you really need a boatload of RAM even if you are just running Enterprise and Desktop on the same machine.
Usually it's easier to set up a second machine.
