Insight 2021.1 and JDBC Oracle
1537
05-31-2021 01:40 AM
Oiligriv
Hello
I'm trying to load Oracle JDBC files in insight but every time I get "This folder does not contain the required JDBC Driver"
The installation is an ArcGIS Enterprise 10.8.1 with Insight 2021.1
I am following the following instructions https://doc.arcgis.com/en/insights/latest/administer/vendor-files.htm
here are the steps I take
  1. I go to the following site https://www.oracle.com/database/technologies/maven-central-guide.html
  2. I download the following file https://repo1.maven.org/maven2/com/oracle/database/jdbc/ojdbc10/19.7.0.0/ojdbc10-19.7.0.0.jar
  3. I create a zip with only the jar file inside it
  4. I connect to the Insight site https://fqdn/portal/apps/insights/index.html#/
  5. I go to setting, connector types, from the drop-down menu I select Oracle
  6. Upload zip file
Tags (4)
Oiligriv
Hello
I was able to import the jdbc into Insight.
for those who need it, in the attachment you can find the file I used.
is tested and working with ArcGIS Enterprise 10.8.1 and Oracle.
Oiligriv
Hello
