Impossible to start portal after installing 10.5.1
1613
06-11-2018 01:45 PM
JulienLengrand-Lambert
Hi there,
We are trying to install our first ESRI site.
I have used the entreprise builder, and everything is setup on the same machine.
I have been able to setup the server and the first web adaptor, but for some reason I have been unable to ever start the portal.
This is the stack trace I get in the logs when starting the portal:
esri@esri:~/arcgis/portal$ cat usr/logs/portal.log
Jun 11, 2018 8:19:34 PM com.esri.arcgis.portal.impl.Main c
INFO: Copying config file from /home/esri/arcgis/portal//etc/portal-config.properties to /home/esri/arcgis/portal/framework/etc/portal-config.properties
Mon Jun 11 20:19:35 UTC 2018 JMXServerContoller.getJMXConnector() failed to return connection - port not configured1577:10
Mon Jun 11 20:19:35 UTC 2018 JMXServerContoller.getJMXConnector() failed to return connection - port not configured1577:11
WARNING: Could not connect to Log service. Writing log message to console.
<Msg time="2018-06-11T20:19:35,314" type="FINE" code="209511" source="Portal" process="1577" thread="1" methodName="" machine="" user="" elapsed="">Copying customization files.</Msg>
<Msg time="2018-06-11T20:19:35,319" type="WARNING" code="209512" source="Portal" process="1577" thread="1" methodName="" machine="" user="" elapsed="">Processing customization line '/webapps/arcgis#home/js/arcgisonline/config.js'.</Msg>
<Msg time="2018-06-11T20:19:35,320" type="FINE" code="209513" source="Portal" process="1577" thread="1" methodName="" machine="" user="" elapsed="">Checking if customization file exists at templatePath /home/esri/arcgis/portal/framework/template/filetokens/webapps/arcgis#home/js/arcgisonline/config.js.</Msg>
<Msg time="2018-06-11T20:19:35,397" type="DEBUG" code="9999" source="Portal" process="1577" thread="1" methodName="" machine="" user="" elapsed="">java.lang.Exception: Cannot read from directory path '/home/esri/arcgis/portal/usr/arcgisportal'. Please check that the location is valid and that the Portal service account has permissions to the location.
at com.esri.arcgis.portal.admin.core.util.ConfigUtil.validateDir(ConfigUtil.java:272)
at com.esri.arcgis.portal.admin.core.util.ConfigUtil.validateAndCreateStore(ConfigUtil.java:358)
at com.esri.arcgis.portal.impl.NodeAgent.install(NodeAgent.java:141)
at com.esri.arcgis.portal.impl.Main.c(Main.java:268)
at com.esri.arcgis.portal.impl.Main.main(Main.java:315)
</Msg>
<Msg time="2018-06-11T20:19:35,400" type="INFO" code="209517" source="Portal" process="1577" thread="1" methodName="" machine="" user="" elapsed="">Installing all the observers.</Msg>
NodeAgent loaded observer 'LogServiceObserver'.
NodeAgent loaded observer 'ConfigObserver'.
NodeAgent loaded observer 'Portal Upgrader'.
NodeAgent loaded observer 'PatchObserver'.
<Msg time="2018-06-11T20:19:35,457" type="INFO" code="218000" source="Portal" process="1577" thread="1" methodName="" machine="" user="" elapsed="">No patch file found, skipping application of patch at startup.</Msg>
<Msg time="2018-06-11T20:19:35,457" type="FINE" code="217000" source="Portal" process="1577" thread="1" methodName="" machine="" user="" elapsed="">Registering 7Zip with the sharing web application.</Msg>
<Msg time="2018-06-11T20:19:35,483" type="INFO" code="209518" source="Portal" process="1577" thread="1" methodName="" machine="" user="" elapsed="">Installing all the plugins.</Msg>
NodeAgent loaded plugin 'ProcessMonitor'.
NodeAgent loaded plugin 'HAMonitor'.
NodeAgent loaded plugin 'UninstallPlugin'.
NodeAgent loaded plugin 'LogFileLimiter'.
Checking in the file system, I have indeed no portal/usr/arcgisportal folder.
I tried to uninstall / reinstall the entreprise builder, without success. I have also tried to install the portal only, without success either. Even after redownloading the whole installer files.
I do not get why the folder isn't there right after installation, and haven't found any resource online about the issue.
Any help would be largely appreciated.
It sounds like manually creating the folder solved the issue.....
