Import layer from portal as geofence in GeoEvent
899
07-18-2022 01:09 AM
ElviraForslund
My goal is to have a geofence in the portal (as a layer) , that can be edited with the editor widget from ArcGIS API, that at the same time can be imported as a geofence in GeoEvent to work as a real time geotrigger.
So far I have published a feature layer from ArcGIS Pro to my Enterprise portal that contains a Polygon layer. I wish to import this feature/polygon layer as a geofence in GeoEvent. However, when selecting the feature layer as Service in GeoEvent, the polygon layer cannot be selected as the Layer for the GeoFence and I fail to import this.
Is there a way to make this work? I have not found a way to import anything from the portal as a geofence in GeoEvent. How do I import a geofence to GeoEvent?
Thank you in advance for any help or suggestions.
ElviraForslund
Hi @MCameron and thank you for your reply.
I did managed to resolve the issue I had with importing GeoFences through the following post : GeoEvent: Failure to Import or Synchronize GeoFenc... - Esri Community .
After this, everything worked as it should!
I apologize for the late reply, but thank you once again for the help!
MCameron
Hi @ElviraForslund
It would be good to gather some additional information, could I ask you to please share with me:
  • Is GeoEvent server installed on the same server machine as the ArcGIS Enterprise server?
  • Are you recieving any error messages when trying to import the layer as a geofence?
  • Could you share a screenshot of what you are seeing when trying to import a geofence?
  • Has this process worked previously, and has now stopped working?
Hopefully, with a little more info we will be able to offer some advice
Martine
ElviraForslund
