I logged in to the instance and tried telnet to both ports 6080 and 6443, telnet works. I tried curl and that worked too. The firewall is open but still I get this error. Am I missing something?
Also ensure the following accounts have full permission for arcgisserver folder (e.g. C:\arcgisserver)
- arcgis server
- <Current User>
Check if all the ports are allowed through firewall as listed in Ports used by ArcGIS Server—Installation Guides (10.5) | ArcGIS Enterprise
Hey Jayanta,
Thank you for responding. The security groups in AWS are open. There are no port restrictions. I have read/write/execute permissions to the folder for all users. I also ran the server diag and it passed all checks. I do not see anything in the logs either.
Why is the URL succeeded by "/services"?
Shouldn't it be just https://xyz.xyz.xyz.xyz:6443/arcgis
I haven't done anything to change the URL. I only gave in the username/password and everything is default while creating the new site.
Hi Sai,
Did you figure out this issue as I am also experiencing same issue.
Baba
Are you trying to automate the installation and setup of ArcGIS Server? I'm having the same issue and I'm wondering if I am running the createsite.bat script too soon after the ArgGIS Server installer has run... and something is not quite available yet.
If I wait a few minutes and run the createsite.bat again... it seems to run okay.
So now trying to figure out how to determine when the service is ready for me to create a site.
Signed in members can post, follow updates, and more. New here? Register a free account.
