I understand that for ArcGIS Server to run properly, the file handle limits for the install user are required to be set to 65535 and the number of processes limits set to 25059. The current file handle limit is 4096 and the number of processes limit is 25059. I've updated these limits by editing the /etc/security/limits.conf file as a super user:
arcgis soft nofile 65535
arcgis hard nofile 65535
arcgis soft nproc 25059
arcgis hard nproc 25059
I verified the edited file, viewing them as the 'arcgis' user. In order for the new values to take effect, I should be able to log out and and back in as the arcgis user, verifying using:
ulimit -Hn -Hu
ulimit -Sn -Su
However, I'm still getting the default values of 4096 and 25059... hmmmm, what other file(s) would I need to edit as this is the only step failing in the AGS Diagnostic Tool? Thanks in advance!
