How to Underline and Change Text Font Size when Creating Arcade Attribute Expression in Map Viewer Pop-Up?
411
10-07-2025 11:24 AM
ChristopherBowering
I am creating an Arcade attribution express to use in Text content in a pop-up configuration.  I would like to underline and change the font size of the title (normal text).  I am imitating the many examples I've seen online but the attribute expression (attempting underline, only, first) just shows this:
Below is the code I am using
Var Fields = [
  "ID: " + $feature.COID + TextFormatting.NewLine,
  "Damage Present: " + $feature.DAMAGE
If (DomainName($feature, 'FLOW') == 'No') {
  return "<UND>" + "Title" + "</UND>" + TextFormatting.NewLine + Concatenate(Fields);
} else {
  return $feature.WEATHER24;
Any thoughts??
Thanks!
MarkBockenhauer
Perhaps you could use an Arcade popup element and use HTML tags.
Something like
Var Fields = [
  "ID: " + $feature.COID + '<br>',
var vTitle = ''
    vTitle = '<u>Title</u><br>' + Concatenate(Fields)
}else {
    vTitle = $feature.WEATHER24
return {
	type : 'text',
	text : vTitle //this property supports html tags
MarkBockenhauer
Something like
Var Fields = [
var vTitle = ''
}else {
return {
	type : 'text',
ChristopherBowering
Thank you very much!  I had thought about involving HTML but wasn't sure how to incorporate it.  Your modification works great.  I added a couple more components to change the font and color as well.
Var Fields = [
var vTitle = ''
    vTitle = '<span style="font-family: Times New Roman, serif; font-size: 20px; color: #8c0122"><b><u>Title</u></b><br></span>' + Concatenate(Fields)
}else {
return {
	type : 'text',
