How to prevent editors from adding features to database
3188
6
11-09-2016 07:42 AM
AaronRowzee
I have an enterprise GIS environment running MS SQL and not the typical SDE environment. I have several people who have edit rights to a handful of datasets within the enterprise database, but I'd like to prevent them from added feature classes to the datasets. Is this possible through ArcGIS or do I need to figure out a way to do it in the MS SQL permissions?
Tags (3)
JoeBorgione
Feature datasets were never intended as a method if organization as they are too often used.  There are a number of threads on this forum that discuss the topic.  That said, you may want to consider individual enterprise data bases as an alternative to feature datasets as a method of organization.  Another alternative is to replicate from the enterprise gdb to a file gdb that allows read only.  When replicating features within a feature dataset you will first replicate the entire dataset, and then move those features out of the dataset as stand alone features on an as needed basis.
That should just about do it....
VikramS
Go to ArcCatalog --> Login in using SDE Admin User Login and Go to the Feature Class --> Manager --> Privileges --> Uncheck editing Privileges for user
AaronRowzee
Thank you for the quick response, Vikram S. But just to be clear, removing "editing" from a dataset will still allow them to edit features within that dataset, just not "edit" the dataset itself by adding new features?
JoeBorgione
There in lies one of the problems with using Feature DataSets within the Enterprise gdb environment.  As I recall, if a particular login is denied write privileges for a feature dataset, the precludes any editing by that login to any feature classes within that feature dataset.
AaronRowzee
So its an all or nothing situation?
Is there a way around this? A method of organization outside of datasets?
JoeBorgione
YungKaiChin
You can simply uncheck 'Insert' for a given editor or editor group or role.
1. Right click the feature class
2. Manage > Privilege
3. Uncheck Insert
