How to create an ArcGIS online connection through ArcGIS Pro?
1218
07-23-2024 12:45 PM
GeorgeJonesRIGOV
Hi all, I am trying to connect to an Enterprise portal to publish a feature service so everybody in my organization can see it and thus utiliize it. However, I am having problems with connecting to AGOL through ArcGIS Pro. Am I doing this correctly?
thanks George
ChrisUnderwood
Hello @GeorgeJonesRIGOV , no you seem to be making an ArcGIS Server connection in your screenshot.
Follow these steps instead to connect to a portal, either ArcGIS Enterprise or ArcGIS Online.
https://pro.arcgis.com/en/pro-app/latest/help/projects/manage-portal-connections-from-arcgis-pro.htm
"Enter the URL for the portal on the Add Portal dialog box and click OK.
GeorgeJonesRIGOV
Exactly - that's it! Just want to connect to an ArcGIS server connection. My goal is to share a web feature service to it.
ChrisUnderwood
You originally stated you have an ArcGIS Enterprise, so you should publish your Feature Service to that.
https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/introduction-to-sharing-web-layers.ht...
An ArcGIS Server connection can only be used to publish to a standalone ArcGIS Server. You cannot use an ArcGIS Server connection to publish data to an ArcGIS Server that is Federated with a Portal to form an ArcGIS Enterprise.
