How to add Orthos to an ArcGIS Server 10.2.2 map service
941
09-22-2016 06:12 AM
JoseSanchez
Hello everyone,
I am currently migrating a map (mxd) used to create a map service in ArcGIS Server 10.0. Because this map has Aerial or Image layers, it does not work in 10.2.2, only when I remove all aerials the service can be created.
How are in ArcGIS Server 10.2.2 managed Aerial layers when creating a map service?
NeilAyres
MVP Alum
Well, how does it "not work". Errors, what happened etc etc.
How are the image layers being managed? In a mosaic? raster dataset? as images?
JoseSanchez
It shows an error when you validate.
AdrianWelsh
MVP Honored Contributor
Jose,
Can you explain what the error said or maybe post a screenshot of this error?
