How do you enable the "Supports Pagination" on a layer at 10.3?
16959
10
12-15-2014 11:23 AM
MichaelGayheart1
I upgraded a service from 10.2.2 and can't find a way to get pagination working. I find documentation about using resultOffset and resultRecordCount if "Supports Pagination" is true, but nothing about how to set it to true.
MichaelGayheart1
In case others are curious, Esri Support responded that the underlying database determines whether pagination is supported. There isn't an advanced configuration setting that can be "enabled" to allow pagination. FileGDB is not supported at 10.3 but could be supported at a later release. Certain versions of enterprise geodatabases support pagination at 10.3.
MichaelGayheart1
HarshalGharat
Michael,
I have my enterprise geodatabase based on SQL Server 2008. I have published my map services based on this backend database and I am not able to get pagination property true.
May I know what backend database will get me pagination to be true?
MichaelGayheart1
From what I was told by Esri support, SQL Server 2012 supports pagination, but 2008 does not. I don't know the technical reason behind the difference in support for the two versions.
HarshalGharat
Thanks Michael for your quick response!
MichaelGayheart1
Just as an update, I was able to use pagination with a fGDB at 10.3.1.
DavidColey
MVP Frequent Contributor
That is good news Michael!
MichaelGayheart1
As an update to my update, I am seeing a slight issue with using pagination at 10.3.1. The original test I ran was using outFields=*, which works. As soon as I specified which fields I wanted to get back, the pagination stopped working. I did find that if I added in the ObjectID field as one of the outFields that it started working again so for now, as far as I can tell, if you want to limit which fields are returned when using resultOffset and resultRecordCount parameters for pagination, make sure to add the ObjectID field. I have a support ticket in to Esri about this.
DavidColey
good to know, thanks
TanuHoque
Is the datasource a FileGDB when you ran into this issue i.e. pagination fails unless you add ObjectID field?
if so, it happens due to a known bug with FileGDB.
In general pagination in ArcGIS Server needs Order By field(s), if you don't specify anything in Order By, it uses ObjectId fields as a default field to sort records (pls see the 2nd bullet in "What's new in 10.3" section in ArcGIS REST API help topic).
When you specify OutFields (without ObjectID field in there) but nothing in Order By, the sql that goes to the database looks something like 'SELECT F1, F2, F3 FROM TABLE1 ORDER BY ObjectID .... ".
FileGDB does not like it when fields in Order By is not part of the SELECT list.
