How do we get rid of the "Documentation assistant" icon at the lower right web browser corner when viewing esri's online documentaion?
405
07-29-2025 10:09 AM
BillFox
MVP Notable Contributor
This icon redacts as a black spot on any printed document
As AGOL admin, settings > AI assistants is not enabled
and don't see anything yet about beta on/off
Reference: https://doc.arcgis.com/en/arcgis-online/reference/doc-assistant.htm
2025-07-29 09_45_00-Add layers to a map or scene—ArcGIS Pro _ Documentation.png
with print background - black dot 2025-07-29 10_02_34-Work with 3D tiles layers—ArcGIS Pro _ Documentation — Mozilla Firefox.png
even with print background off it redacts as a white spot 
without print background - white dot 2025-07-29 10_03_46-Work with 3D tiles layers—ArcGIS Pro _ Documentation — Mozilla Firefox.png
Leena_Abdulqader
Hi @BillFox, I don't think there is an option to hide it yet. But as a workaround, you can do it using the dev tools in your browser.
F12 > Leena_Abdulqader_0-1753842553823.png (Select an elemnt in page to inspect) am using Chrome here> Click on the "Documentation Assistant" button > In the Elements tab, you’ll now see the corresponding <esri-doc-assistant-button> or a <div> that wraps it> Right-click on that element in the DevTools panel and choose "Delete element".
The icon should disappear, and you can print that page.Unfortunately every time you refresh or access a page, you need to do it.
Another workaround I could think of is using the reader mode in the browser, but I think this is only available in Firefox. And you can print from it.
I hope this helps!
SimonSchütte_ct
MVP Regular Contributor
If you use an adblocker like UBlock Origin, you could select the element and auto-block it.
In UBlock you can use the lightning symbol to remove the icon from the current session. With the pipette icon you can remove it always.
Overlay is now removed:
Alternatively there are neat Extension like Page edit or Print Edit WE that let you edit websites before printing.
Leena_Abdulqader
This is awesome I didn't know about this. Thank you! @SimonSchütte_ct
